Dustin278's avatar
Dustin278
Apprentice
Apr 19, 2018
Orbi with TP-Link HS110 Smart Plug
My HS110 TP-Link smart plug seems to reset my whole Orbi system when it is close to the Router but if I plug it in near a Satellite it is fine.. Anyone else having this issue? I have the latest firmware 2.1.3.4 and everthing else has been smooth for months until I noticed this the other day..
1 Reply
  • FURRYe38's avatar
    Reset or Reboot?
    Was a factory reset performed after the FW update and set up from scratch. Please try this if you didn't.
    How close is the smart plug from the router and satellite?
    Try at farther distances.
    Not everyone has a smart plug so not everyone may have this problem.
