alex8828
Aug 01, 2019Aspirant
Orbi with Verizon Fios
Hello all, This is my first post since owning my Orbi system. I have a question I have Verizon Fios with internet tv and phone and I am currently using my Fios router G1100 as the primary router and...
Aug 01, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Option #2 should work for you.
- punkoramboAug 02, 2019GuideHas anyone had success with Option #2 with the G1100 from FiOS? I’ve read that the DMZ setting isn’t a true DMZ and there is still the double NAT problem.
- FURRYe38Aug 02, 2019Guru - Experienced User
Give this a try and see. Ask your ISP if the G1100 can be bridged if possible. If DMZ or bridging doesn't work, then configure the Orbi for AP mode.
punkorambo wrote:
Has anyone had success with Option #2 with the G1100 from FiOS? I’ve read that the DMZ setting isn’t a true DMZ and there is still the double NAT problem.- alex8828Aug 02, 2019AspirantI’ve tried calling Verizon Fios regarding configuring the router to be secondary and they are not very helpful.
