alex8828
Aug 01, 2019Aspirant
Orbi with Verizon Fios
Hello all, This is my first post since owning my Orbi system. I have a question I have Verizon Fios with internet tv and phone and I am currently using my Fios router G1100 as the primary router and...
punkorambo
Aug 02, 2019Guide
Has anyone had success with Option #2 with the G1100 from FiOS? I’ve read that the DMZ setting isn’t a true DMZ and there is still the double NAT problem.
Aug 02, 2019Guru - Experienced User
Give this a try and see. Ask your ISP if the G1100 can be bridged if possible. If DMZ or bridging doesn't work, then configure the Orbi for AP mode.
- alex8828Aug 02, 2019AspirantI’ve tried calling Verizon Fios regarding configuring the router to be secondary and they are not very helpful.
- punkoramboAug 02, 2019GuideI found this post which seems to have positive feedback. It explains how one person supposedly bridged his G1100 and kept all of the Fios STB functionality even with Coax coming from the ONT. I have not tried it yet but if someone does and it works please post back here. Otherwise I’ll try it when I can and post back after.
http://www.dslreports.com/forum/r31057540-Networking-HOW-TO-Bridge-G1100-So-your-Router-becomes-Primary- FURRYe38Aug 02, 2019Guru - Experienced User
I would give the DMZ a test try first with the Orbi to see if this works for you. If not, Let us know if the bridging work around works for you.
Good Luck.
