AKLGUY
Jan 09, 2019Apprentice
Orbi with wifi 6
Has anyone seen the tech specs on the newly announced Orbi?
I hope the AC speeds to the units will be faster than the 867MB (as well as the faster backhaul)
AKLGUY
Thanks. I see it has the AX backhaul which is fine. But what about the actual PCs to the Unit speeds
Secondly if you are using ethernet backhaul. They should open up the dedicated band for the backhaul for devices to connect :p
Jan 09, 2019Guru - Experienced User
Depends on client device or adapters used in the PC. Currenly nothing on the market yet for AX in regards to client HW.
