Chadmack
Feb 23, 2017Follower
Orbi with wireless printer
I just recently set up Orbi with router and one satellite. All devices and coverage are great, only issue I have is my Brother Multi-Function wireless printer (MFC-J4510DW) will no longer print. When ...
qaxorivet
Apr 24, 2017Aspirant
It seems that you facing network issue while printing. Check LCD screen of your printer and notice that is there any error displayed on it? If yes, then fix it by using appropriate solution for it. But also keep in mind that sometimes printer errors are occurs due to corrupted driver files, poor and bad version drivers, also becuase of old PC updates etc. Get more information and troubleshooting ideas like above in Brother MFC-J4510DW Manual and get rid of your problem.
