Chadmack
Feb 23, 2017Follower
Orbi with wireless printer
I just recently set up Orbi with router and one satellite. All devices and coverage are great, only issue I have is my Brother Multi-Function wireless printer (MFC-J4510DW) will no longer print. When ...
rtbinbend
Mar 06, 2017Tutor
Problem solved. Even though the printer was connected and my devices could see it, they couldn't print to it. I reset the printer to its factory settings, deleted all drivers from my computer and then started fresh as if I had just unboxed the printer and that did the trick.
jdpone
Dec 27, 2017Aspirant
Thanks for this post! It helped me with a Canon printer. I reset the LAN settings to factory, re-setup, and all works now :)
