kmp18
Jul 27, 2018Initiate
Orbi with Xfinity modem/router
I have an Xfinity modem/router (model TG1682G) and just purchased a tri-band orbi to handle dead spots in the house. I researched and saw that most recommended to enable Bridge mode on my Xfinity mo...
JammasterC
Nov 14, 2018Star
I have the Arris TG1682G Moden/Router for Xfinity.
Wifi is "Off" and "Bridge Mode" is Disabled on the Arris. I found "Enabling" Bridge Mode caused no internet.
Also "Mocca" is enabled because multi-room DVR needs it.
I am currently using a Netgear WNDR3700 router (DD-WRTWNDR3700).
I am waitng for the Orbi RBK50 to arrive tomorrow.
So we'll see if I get a simple plug n play.
Nov 14, 2018Guru - Experienced User
Well Bridge mode would be preferred and after setting bridge mode, you should have powered OFF the modem. Connected the Orbi to the modem. Power ON the modem, let it sync, then powered ON the Orbi router and walk thru the setup wizard. The orbi should have found internet access and set it up for you.
I would try option #2 of the suggestion however while the modem is not bridged.
