aupton
Feb 24, 2019Tutor
Orbi [WLAN access rejected: incorrect security] from MAC address ... post auto upgrade to v2.2.1.210
My Orbi recently auto-upgraded to the latest version of firmware (with great timing as I had just gone away for two weeks for work so I had a family at home missing internet access more than they mis...
- Feb 24, 2019
Thanks, I just tried to reapply and that didn't work. However, I think that I may have just found the problem. I just noticed, when I looked at the logs that the date (at the top of the page) was wrong. I went to the NTP settings and saw:
Current Time: Wednesday, Sep 26, 2018 20:58:10
Warning: The Orbi Router failed to connect to NTP server, please check your internet connectivity or try another NTP server.
The correct date and time are important for security validation so I think that this may be the root of the issue. I am trying to use a different NTP server pool with no success.
ekhalil
Feb 24, 2019Master
It can be that the AP Mode setting is -somehow- "forgotten" by Orbi after the SW update, can you please go to the Route / AP Mode setting page and again mark the AP Mode (even if it's already marked) and click on Apply as follows:
aupton
Feb 24, 2019Tutor
- ekhalilFeb 24, 2019Master
Do you currently have "Use default NETGEAR NTP server"? I have this setting and it works just fine.
((EDIT)) Try to repeat the "APPLY" again if you get the error. When I click appy I get the same error a number of times before it finally works! :)
- auptonFeb 24, 2019Tutor
Yes, it was defaulted to that initially. I only just tried changing it to another NTP server (which I can access correctly via my computer going through this AP and Billion router. It still said that it couldn't access the NTP server after applying. I forced a reboot and the date and time is now correct (I am using 0.uk.pool.ntp.org) for the NTP services. Now my devices are able to reconnect (after reauthenticating).
Thanks for your help.
Great the know things are working again for you :)
- tekn0684Oct 13, 2021Aspirant
issue: Goes offline all devices mobile, PC also game console when this comes up in the router log.
[WLAN access rejected: incorrect security] from MAC address b0:fc:0d:0c:40:11, Tuesday, October 12, 2021 12:24:43
My router info above, I have two attennas including the router. Works fine about 3 or 4 years now, and suddenly security issue as i posted above started to pop up in the logs. reason looking at the router logs was everytime this happens the whole network goes offline for about a minute or more, if streaming I get cut off instantly and it became annoying.
on my game console had switched the NAT time to my time zone and no more issues, thank you to this post for all your help.
- FURRYe38Oct 13, 2021Guru - Experienced User
Be sure the device has the correct wifi pass work.
What security mode are you using on the Orbi RBR? WPA mixed mode? WPA2 AES only?
