AndrewJJP
Oct 08, 2021Aspirant
Orbi won’t reset password. Error 400.
I wanted to log in to my router but I don't know the password. Generally I use the Touch ID on the app but I tried it from the browser. I went through the reset procedure, entering the serial num...
- Oct 08, 2021Thanks very much
Oct 08, 2021Guru - Experienced User
If you don't remember the password and password recovery isn't working (or wasn't setup, it still asks the questions but there isn't a correct answer) then a reset is going to be the only option to get back in.
Your Armor will work.
I've reset my routers hundreds of times and I haven't ever bricked one during a reset.
Just make sure to push and hold reset for 7-15 seconds while its powered on.
- AndrewJJPOct 08, 2021AspirantThanks very much
