QuiltyC
Feb 28, 2021Aspirant
Orbi won’t work with BluOS
I have a NAD M50 media streamer which is wired via Ethernet which I can see at its ip address and on my desktop which is also Ethernet. The player is controlled by a WiFi app on an iPad, BluOS, whic...
Mikey94025
Feb 28, 2021Hero
I agree with the above recommendation - If your wired ethernet devices are connected to the Uverse router then it would be better to standardize on the one Orbi home network and instead connect them by ethernet to your Orbi base/satellite. The only thing connected by ethernet to Uverse would be the Orbi base.
Furthermore, best to put your Uverse into "bridge mode" and let Orbi serve your DNS. It's simples if Orbi is your one home network and does everything for you.
