QuiltyC
Feb 28, 2021Aspirant
Orbi won’t work with BluOS
I have a NAD M50 media streamer which is wired via Ethernet which I can see at its ip address and on my desktop which is also Ethernet. The player is controlled by a WiFi app on an iPad, BluOS, whic...
CrimpOn
Feb 28, 2021Guru - Experienced User
QuiltyC wrote:I have a NAD M50 media streamer which is wired via Ethernet which I can see at its ip address and on my desktop which is also Ethernet. The player is controlled by a WiFi app on an iPad, BluOS, which has not worked since i installed the Orbi. Nothing on the WiFi network can see it. The BluOS app on my iPad cannot find the NAD player. I tried enabling iptv. My internet connection is through a UVerse router which I use the only dhcp server on the network. It's WiFi is off.
I have plugged, unplugged, power-cycled, rebooted to factory settings, and nothing works.
Was this working before the Orbi system was installed?
Are the NAD and the desktop both connected to the Orbi ethernet, or are they connected to UVerse?
Would you mind reporting the IP addresses of the NAD, desktop, and iPad?
Thanks
QuiltyC
Thanks
It was working before the Orbi as installed.
The Orbi is connected directly to the UVerse router and the NAD a connected through an unmanaged switch which connects to the UVerse router.
The ip addresses are:
NAD 192.168.1.93
Desktop 192.168.1.155
iPad 192.168.1.190
