steeve725
Mar 10, 2019Guide
Orbi won't connect remotely
Just got my orbi a couple days ago. I have the orbi RBK33 with plug in satellites. It has firmware version 2.2.1.210 I'm away from home and won't be home for a couple hours and my orbi won't ...
ekhalil
Mar 10, 2019Master
If you enabled Remote Management in the web GUI then you can login remotely to Orbi using the web GUI only. So browse to https://xxx.xxx.xxx.xxx:8443 (if you did not change the port in the settings) and you will get the Orbi login page.
For the Orbi app there is another Remote Management that needs to be enabled. In the app go to Home >> Settings >> Remote Management and enable it.
- steeve725Mar 10, 2019GuideHi.
Yes I enabled that in the app when I set up the router.
I checked in the app and the it showed green as enabled still.
I turned it off, then back on and it now works.
Just a little bug I guess.
Thanks.
