steeve725
Mar 10, 2019Guide
Orbi won't connect remotely
Just got my orbi a couple days ago. I have the orbi RBK33 with plug in satellites. It has firmware version 2.2.1.210 I'm away from home and won't be home for a couple hours and my orbi won't ...
steeve725
Mar 10, 2019Guide
Hi.
Yes I enabled that in the app when I set up the router.
I checked in the app and the it showed green as enabled still.
I turned it off, then back on and it now works.
Just a little bug I guess.
Thanks.
Thanks.
