TrevorLRad
Jan 20, 2019Follower
Orbi wont connect to my internet nor my ps4
My RBR20 says the internet is online and has 1 satellite connected. The only issue is as i check on the your products tab it says im not connected to my internet. I try to connect my orbi wifi to my p...
Feb 11, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
Has a power off of the ISP modem and Orbi router for 30 seconds then back on with the modem first, then the Orbi router been performed?
TrevorLRad wrote:
My RBR20 says the internet is online and has 1 satellite connected. The only issue is as i check on the your products tab it says im not connected to my internet. I try to connect my orbi wifi to my ps4 and it comes up with a CE-37813-2 error code.
