Waimeamike
Dec 25, 2019Aspirant
ORBI wont stay connected with CM1150V Modem
I have the Orbi RBR50v2 with 2 RBS50v2 satellites. I recently shifted from AT&T to Comcast so I purchased the CM1150V Nighthawk Modem for Xfiinity Voice. Plugged everything in things appeared to be...
Waimeamike
Dec 27, 2019Aspirant
My router firmware is V2.3.5.30.
All WiFi devices drop regardless of satellite they are connected to. I
don't know about wired devices as the only other wired device is a Phillips lighting wifi device for smart lights. I will need to plug in my laptop with the connection monitor running and see if the problem is still there.
As I said earlier, the phones which run off the router do not drop.
My home is 3100 square feet, two story. It has a metal handrails on the stairway which make a perfect faraday cage in the middle of my house so I have one Orbi satellite hard-wired to the Orbi router. The setup worked perfectly when I was on the AT&T Modem/Router. The trouble began when I inserted the Nighthawk Multi-Gig modem with Infinity Voice (CM-1150V). There are no adjustable features on the modem other than factory reset.
Dec 28, 2019Guru - Experienced User
So its only the satellites that are having issues?
Couple things you could try or it could be.
how far apart are they from router/satellite? 30 ft is the minimum distance needed
You can try enabling/disabling these: beamforming, mu-mimo.
Handrails alone aren't goign to make a faraday cage. Maybe if the whole stairway is lined with hvac but not just the handrails.
the other option is that some have been issues with the v2.3.5.30 firmware with stability. Some people fixed it with a simple factory reset of all the devices and manual re-install. If it doesn't work you can manually downgrade the firmware to an earlier version to see if it helps.
