mehanley
Dec 01, 2016Follower
ORBI working very well but Cisco VOIP phone wired connected to router not working
I installed/setup the new ORBI router with the two satellites without problem yesterday however my work provided CISCO VOIP phone SPA504G although I have it directly wired to the router and have plug...
peteytesting
Dec 01, 2016Hero
i have the orbi system here and have a siemans gigaset c610a ip phone set connected to it and it registers and works without issue
the gigaset is connected to the orbi router via ethernet and the sip alg is enabled
so you might need to first figure out if the cisco is not connecting ethernet wise or just not connecting voip wise for registration
you may need to make sure the cisco also is set to obtain dhcp and dns from the orbi and doesnt have a static ip set on it
pete
