Sdspark58
Mar 26, 2019Tutor
Orbi works then does not work
Bought this a few months ago and at first seems to always work fine. Now everyone claims the Wi-Fi sucks. At time some devices work fine while others are connected but it’s like the internet is out. ...
Sdspark58
Mar 27, 2019Tutor
2500 sq ft. They are on different floors apx 30 to 40’ apart. But signal is not just lost on satalite it’s the whole system. A device can be connected to the satellite and work fine and a device on the main router will all the sudden stop working while another device on the main works fine.
Mar 27, 2019Guru - Experienced User
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
I would also try to get the FW updated. You need to update the RBS first, then the RBR lastly.
