dhark4311
Feb 09, 2017Aspirant
Orbi WPS and Canon Selphy CP1200
Hi there I want to connect my Canon Selphy CP1200 Wifi Printer to the new Orbi Access Point, but the Printer doesn't see the SSID and also trying with WPS fails. I'm using standard settings/secu...
- Feb 09, 2017
Hi again!
It seems I solved my problem/question ;-) The Canon Selphy Printer expects that the Channel Range is between 1 - 11 (not Auto).
I set the 2,4 Ghz to Channel 10 and voila it works ;-))
Not really the best solution, but I can live with that !
Thanks anyway for taking the time to look into this ;-)
Kind regards !!
dhark4311
Hi there !
Yes, I restarted the printer many times to no avail. Also all other devices I have can connect without issues.
That is a Windows 10 PC, 2 Mac's, IPad, iPhone and also my Sony Xperia M Phone work without a hitch.
So it's really this printer that gives me some headache's ;-)
Kind regards.
dhark4311
Hi again!
Kind regards !!
- Streak2Feb 09, 2017Master
I was just about to get you to try that.
You should now be able to set the Orbi back to Auto now without affecting the printer.
- dhark4311Feb 09, 2017Aspirant
Hi again!
Thanks ;-) I didn't think of that !! Set back to Auto and also restarted the Printer to make sure and stills prints like a charm !!
Thanks again and kind regards ;-)
