billycrystal
Jan 12, 2019Initiate
Orbi w/Ring Stick Up Camera (battery)
Orbi RBR50 & RBS50 V2.2.1.210
Security WPA2-PSK [AES]
Ring iOS App v5.9.2
AT&T w/WiFi Assist turn off
I have a Ring Pro doorbell on the network with easy install and no operational issues...
- Apr 21, 2019
I had problems connecting my Ring Spotlight cam. Apparently the Ring only supports Channels 1 through 11; whereas the Orbi supports Channels 1 through 13.
I changed the Orbi 2.4 from 'Auto' channel to a hard coded channel and voila the Ring could connect.
DougB628
Apr 21, 2019Apprentice
You're using D-Link DCS cameras? Which model(s)? I have 7 DCS-2630L's, and after going back to just one SSID for both 2.4 and 5GHz networks, I'm back to spurious connecton drops with my cameras. I went to split SSID's trying to resolve that problem, but now that I've swtiched back, my camera problems are back.
psmedley
Apr 21, 2019Tutor
