seachellemz
Nov 20, 2022Aspirant
Orbi w/XFI and Port Forwarding
I have an Xfinity XFI Gateway front-ending an Orbi Mesh Network. I have a web server that I am hosting on my network. Right now I am unable to access my website from outside of my network. Here is...
CrimpOn
Nov 20, 2022Guru - Experienced User
If the gateway is really in bridge mode, then port forwarding rules are not relevant. Could you try an experiment and use a different port number (as a test)
- CrimpOnNov 20, 2022Guru - Experienced User
Could you specify the exact model of Xfinity xFi gateway (there appear to be several). I'd like to find the user manual and see how Xfinity describes Bridge Mode.
Your hunch is entirely correct that a typical "Double NAT" makes exposing servers to the internet very difficult. There are several common solutions:
- Place the ISP device into Bridge Mode.
Leave the customer router in router mode.
Create port forwarding rules on the customer router. - Leave the ISP device in router mode.
Place the customer WiFi equipment in Access Point (AP) mode.
Create port forwarding rules on the ISP router. - Leave the ISP device in router mode.
Put the customer router in the ISP router DMZ.
Create port forwarding rules on the ISP router to forward to the IP address of the customer router.
Create port forwarding rules on the customer router to forward to the local server.
I have done this successfully, but it is cumbersome and tedious. If "nothing else works".... maybe.
(I just did it to verify that it is possible. I actually forwarded ports through three routers.)
I asked about trying a different port because 443 is sort of "special". The Orbi router accepts connections on port 443 for the Orbi web browser interface. I have successfully forwarded port 80 through my Orbi router, but do not currently have a web server that I can expose to the internet for a test.
- CrimpOnNov 21, 2022Guru - Experienced User
Remembered that my security cameras have a web server that can be set to both http (80) and https (443). Forwarded port 443 through the router to the camera. Disconected phone from WiFi to use LTE and web browser connected to camera. (web interface unusable on the tiny phone screen, but it certainly connected.)
Plus Shields Up! reported port 443 "open" which it does only if a device on the LAN actually responds to a connection request.
https://www.grc.com/shieldsupThe xFi router does not appear to be in Bridge Mode. Would either call Xfiinity to get help (and maybe very frustrated) or put the Orbi in the xFi router DMZ.
- seachellemzNov 20, 2022AspirantSo are you suggesting I just don’t need to port forwarding rule on the Xfinity Gateway?
I did try just eliminating the port forward rule on the Xfinity gateway, but that still did not work. .
