seachellemz
Nov 20, 2022Aspirant
Orbi w/XFI and Port Forwarding
I have an Xfinity XFI Gateway front-ending an Orbi Mesh Network. I have a web server that I am hosting on my network. Right now I am unable to access my website from outside of my network. Here is...
CrimpOn
Nov 20, 2022Guru - Experienced User
If the gateway is really in bridge mode, then port forwarding rules are not relevant. Could you try an experiment and use a different port number (as a test)
seachellemz
So are you suggesting I just don’t need to port forwarding rule on the Xfinity Gateway?
I did try just eliminating the port forward rule on the Xfinity gateway, but that still did not work. .
