Topside
Aug 17, 2017Follower
Orbi
The white Orbi cases are smooth plastic but soft unlike any other electronic plastic. How can they be cleaned? Specifically removing ball point ink scribbles by a toddler. Asking for a friend . . .
peteytesting
Aug 17, 2017Hero
hi , it really depends if its ink type ball point pen or gel type but try
get amonia and a cotton bud and apply the amonia just to the actual ink and let it sit for a while and then use another cotton bud to dab it off
note : i have not tried this but suggest you do a small test sample on the back of the unit forst to make sure it doesnt effect the plastic
