magatoni
Dec 29, 2017Aspirant
ORBI
Hi there gang! I have a quick question I think I have double nat as I have an orbi installed (router mode) behind a comcast gateway that is broadcasting a wifi signal too and is not in bridge mode....
Boomerang3
Dec 29, 2017Apprentice
I basically just went thru and completed as of today a similiary exercise. I replaced one router and several access points with the Orbi. I have as of this posting 47 devices connected out of a possible 70.
You have probably completed this effort, but 1). I had exported my config from my previous router to get a copy of reserved IPs and Ports forwarded. 2). Just go for it and be prepared to make a couple round robins on the various devices to reconnect them. 3). I renamed my SSID so that made it a requirement I visit each device, which I wanted to anyway. If you don't changed SSIDs, you might get lucky and everything reconnets.
