Thursdayschild
Oct 06, 2018Follower
Orbi
My family and I are looking to invest in the Orbi mesh system. Can anyone advise the difference between the RBK 50 and 53 Versions? Many thanks
Oct 06, 2018Guru - Experienced User
The kits are the same hardwardwise, The kits I believe are different in that the RBK50 has just the one base router and 1 satellite while the 53 has 2 satellites. You can look at the spec here for each system:
https://www.netgear.com/support/product/orbi.aspx
