drsamwaa
Dec 07, 2018Initiate
ORBI
PLEASE PLEASE PLEASE ALLOW SPLIT SSID !!! Many people are asking for the option and I have equipment that does not work with band steering
Feb 05, 2019Guru - Experienced User
You can try to set the 5Ghz power output on the Orbi from 100% to 25%, then move the mobile setup device far away from the Orbi router as possible, Turn off the satellites temporarilily as well while you attempt to get the mobile setup device to connect to the 2.4Ghz radio.
FYI, the Mfr of these IoT devices need to proper develop and test there products on routers systems that support a single SSID name and PW and MESH systems. The Mfr is not ensuring that there setup software can allow for a mobile setup device to be connected to a 5Ghz wifi source while the mfr IoT device is connected to the 2.4Ghz wifi source. This is the responsibility of the IoT Mfr to effect this and ensure there devices are working correctly on MESH wifi systems that use Smart Connect. There setup software should be able to handle having a mobile setup device on a 5Ghz wifi and there IoT device on 2.4Ghz and get them connected since the 2.4Ghz and 5Ghz wifi are on the same network. The handling of the setup software needs to be reviewed by the IoT Mfr.
argold wrote:
Yes please. I can not configure IoT power socket switches, which can only use 2GHz APs, when my phone locks into the Orbi 5GHz signal. I need either to be able to disable the 5GHz band AP else be able to configure the 2GHz and 5GHz APs with different SSIDs so that I can steer my phone to the 2GHz band. Right now I get around this by using a different antique phone that only has 2GHz, but needing a sifferent phone to configure the IoT devices is a PITA.
argold
Feb 05, 2019Guide
Thanks for the suggestion but if Netgear requires that we must to resort to kludges then mine of using a geriatric 2GHz only phone is working well enough.
- FURRYe38Feb 05, 2019Guru - Experienced User
It would be the IoT Mfr that is having you do that my limiting there setup software that doesnt' work right on MESH systems.
Good Luck.
