drsamwaa
Dec 07, 2018Initiate
ORBI
PLEASE PLEASE PLEASE ALLOW SPLIT SSID !!! Many people are asking for the option and I have equipment that does not work with band steering
argold
Jan 28, 2019Guide
Yes please. I can not configure IoT power socket switches, which can only use 2GHz APs, when my phone locks into the Orbi 5GHz signal. I need either to be able to disable the 5GHz band AP else be able to configure the 2GHz and 5GHz APs with different SSIDs so that I can steer my phone to the 2GHz band. Right now I get around this by using a different antique phone that only has 2GHz, but needing a sifferent phone to configure the IoT devices is a PITA.
ekhalil
Feb 07, 2019Master
You can temporarly disable the 5 GHz band until you do the activation of your IoT devices then when ready return the 5 GHz back as follows:
- Switch off the satellites if you don't want to do the same procedure on router and all satellites
- Enable telnet on the router.
- Telnet to router and enter the following command:
- > ip link set down dev ath1 (ath1 is what you should get from the command > config get wl5g_NORMAL_AP)
- Now the 5 GHz will be down
- When you're ready, return the 5 GHz back with the following command:
- > ip link set up dev ath1
- argoldFeb 07, 2019Guide
Thank you for that suggestion.
