Ben_Alb
Feb 19, 2019Aspirant
Orbi
My orbi router keeps disconnecting certain devices from the internet at times around 10 pm despite no internet block in place...
Feb 19, 2019Guru - Experienced User
What FW is currently loaded?
What model Orbi do you have?
Is the Orbi system operating in Router or AP mode?
What devices do you have connected to the system? wireless and wired?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6.
