B0st0nbruins19
Mar 03, 2019Aspirant
ORBI
After pausing my desktop through the Orbi app and resuming it later in the day, I can no longer get internet to my PC. The desktop is hard lined to the satellite and has never had issues prior to paus...
ekhalil
Mar 03, 2019Master
Access Control does not work properly in the software 2.2.1.210. Please upgrade to the latest software 2.3.0.32 which has improvements in this area.
To solve this issue on 2.2.1.210 you need to completely disable Access Control.
B0st0nbruins19
Everything is updated. I’ve reset everything. I’ve tried a different Ethernet cord and port on the orbi. Still nothing. It shows access sometimes with the name of my network but then it says it’s not secure and therefore won’t work.
- B0st0nbruins19Mar 03, 2019AspirantCorrection. When I update it through the orbi app, it says all firmware is up to date, but my firmware is 2.2.1.210. So now I’m confused
- ekhalilMar 03, 2019Master
B0st0nbruins19 wrote:
Correction. When I update it through the orbi app, it says all firmware is up to date, but my firmware is 2.2.1.210. So now I’m confusedThen your software is still on 2.2.1.210.
Please update manually.
- Blanca_OMar 05, 2019NETGEAR Employee Retired
Were you able to update the firmware? Please let us know of the result.
Blanca
Community Team
