Nyirishman1877
Apr 24, 2019Aspirant
ORBI
I Constantly keep having to reboot my orbi router 9pm every night. Since it seems to lose internet connection. How can I fix this? Hope someone can help me
michaelkenward
Apr 25, 2019Guru - Experienced User
You'll have to tell people a bit more.
How do you know that the router loses the Internet and not stuff connected to it?
Is this wifi connections? Wired things?
What about the modem in front of this router?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
- Nyirishman1877Apr 25, 2019AspirantAll of my devices connected to satellites wired or wireless lose connection. I have firmware 2.3.1.44 just updated last week. Had the same issue with the old firmware as well. My cable modem has all solid lights
- gr8shoApr 25, 2019VirtuosoSome users with cable modems have better operation of the Orbi configured in AP mode. The switch is accessible via the web management console. http://orbilogin.net/
- Nyirishman1877Apr 25, 2019AspirantWhat is the different between router and access point. Will the speed be different?
