Nyirishman1877
Apr 24, 2019Aspirant
ORBI
I Constantly keep having to reboot my orbi router 9pm every night. Since it seems to lose internet connection. How can I fix this? Hope someone can help me
Nyirishman1877
Apr 25, 2019Aspirant
All of my devices connected to satellites wired or wireless lose connection. I have firmware 2.3.1.44 just updated last week. Had the same issue with the old firmware as well. My cable modem has all solid lights
gr8sho
Apr 25, 2019Virtuoso
Some users with cable modems have better operation of the Orbi configured in AP mode. The switch is accessible via the web management console. http://orbilogin.net/
- Nyirishman1877Apr 25, 2019AspirantWhat is the different between router and access point. Will the speed be different?
- michaelkenwardApr 25, 2019Guru - Experienced User
Nyirishman1877 wrote:
What is the different between router and access point.Router mode means that the Orbi does the router bit, handing out addresses for things on the network, for example.
Access point mode hands this task to your modem/router, leaving the Orbi to handle wifi.
Will the speed be different?No.
- Nyirishman1877Apr 25, 2019AspirantSo since I just have a cable modem. I should change from router to access point?
