Nyirishman1877
Apr 25, 2019Aspirant
ORBI
I Constantly keep having to reboot my orbi router 9pm every night. Since it seems to lose internet connection. How can I fix this? Hope someone can help me
michaelkenward
Apr 25, 2019Guru - Experienced User
Nyirishman1877 wrote:
So since I just have a cable modem. I should change from router to access point?
Not necessarily.
What is this cable modem? Make and model?
Is it a modem/router? Does it have a row of LAN ports on the back? Does it also dish out wifi?
Nyirishman1877
Arris tm602
No lan ports and does not have built in wifi
- michaelkenwardApr 25, 2019Guru - Experienced User
Looks like a standard cable modem with the complication of a telephone socket. No built-in router.
Your Orbi should work in router mode.
It is hard to see how the router can interrupt your connection, especially at the same time. It is easy to blame the router for this sort of thing, but it smells more like something going on on the telephone network.
