Orbi555
May 02, 2019Aspirant
Orbi
Can I use an orbi satellite with the Nighthawk X6 as the base?
May 02, 2019Guru - Experienced User
If you want a extender for your X6 router, then you would need to review the EX8000 extender that would be the match for your router.
https://www.netgear.com/support/product/EX8000.aspx
- Orbi555May 02, 2019Aspirant
Thanks for the help.
