Kaysee326's avatar
Kaysee326
Follower
May 23, 2019
Orbi
Hello   Are you able to buy additional Orbi satellites to connect to the existing Orbi network.    ie - if i buy a set of 3 (Router and 2 satellites), can I just buy an additional satellite for m...
  • FURRYe38's avatar
    May 23, 2019
    Yes you can. RBS or RBW models will work. RBRs only work as main router or in AP mode. They can not work as a satellite.
