JSchepers
Jul 08, 2019Aspirant
Orbi
Good afternoon, I might be asking a question that has been answered multiple times before... When installing an Orbi system, 1 router, 3 access points, do the 3 AP's have to be in reach of the r...
BBB73
Jul 08, 2019Apprentice
JSchepers wrote:Good afternoon,
When installing an Orbi system, 1 router, 3 access points, do the 3 AP's have to be in reach of the router or does one AP forward the signal to another one? The reason I'm asking the question is because in the manual of the Orbi system, the drawings seem to suggest that all AP's have to be in reach of the router. My desired setup would be to have the router at ground level and then one AP per level. Will this work?
Thank you for your time and support.
Br,
Jérôme
Hi, the satellites can forward the signal from the router when the option Enable Daisy-Chain Topology is enabled under Advanced > Advanced Setup > Wireless Settings.
JSchepers
Thx for your swift reply. It makes sense but I can't seem to find any reference of this option in the manual. Is it a recent addition?
- FURRYe38Jul 08, 2019Guru - Experienced User
Daisy Chain has been around for a while now.
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
https://kb.netgear.com/000048459/How-can-I-see-if-my-Orbi-WiFi-System-is-using-daisy-chain
https://kb.netgear.com/000048460/How-do-I-disable-daisy-chain-topology-on-my-Orbi-WiFi-System
JSchepers wrote:Thx for your swift reply. It makes sense but I can't seem to find any reference of this option in the manual. Is it a recent addition?
