mryrstvr
Jul 19, 2019Follower
Orbi
I have a Netgear EX7000 and Nighthawk X4 range extenders. I set up Orbi RBR50. Can I still use my 2 Netgear Range Extenders with our Orbi or are they entirely different systems? Sorry I am no...
ekhalil
Jul 19, 2019Master
Yes, you can use your old extenders with Orbi but please note the following:
1. You should set the radio on the extenders on different channels than those used in Orbi.
2. You should use a different SSID in the extenders that the one used in Orbi.
