Mbluman
Jul 27, 2019Aspirant
Orbi
How do I move a camera from 5 ghz to 2.4 ghz?
Jul 28, 2019Guru - Experienced User
You can disable the 5Ghz SSID temporarily to see if the camera will connect to the 2.4Ghz radio SSID. Under Advanced Tab/Advanced Settings/Wireless Settings. If you try this, see if the camera connects, if it fails to work even on 2.4Ghz, then there maybe problem with the camera sicne your other cameras are working.
