GuyVerachtert
Sep 27, 2019Aspirant
Orbi
Hi Everyone, When using an orbi with satelites, are the satelites choosing what AP the client device should connect to, or are the client devices "roaming" thru the network ? Kind regards, ...
Sep 27, 2019Guru - Experienced User
Based on signal, quality and noise, clients will choose the frequency and which wireless source to connect too.
GuyVerachtert
thank you for your reply.
So if a device does not support roaming, the mesh network has no advantage ?
kind regards,
Guy
- FURRYe38Sep 27, 2019Guru - Experienced User
Only for roaming. To get a device to connect to any particular wifi course, the devices wifi radio would need to be temporarily turned off then back on.
- CrimpOnSep 27, 2019Guru - Experienced User
(I hit the wrong button, and the option to "Edit Post" seems to have disappeared.)
GuyVerachtert wrote:So if a device does not support roaming, the mesh network has no advantage ?
In my case, the vastly superior separate 5G backhaul channel was a big draw. Investing in "WiFi extenders" does not produce the same coverage area or throughput. And, I do not know if they "roam", but our smartphones and tablets appear to move between the router and satellite automatically.
- GuyVerachtertSep 27, 2019Aspirant
Thank you all for the reply !
I understand the advantages, but i have a very perticular use case...
I have a medical device that will connect once to a wifi network, and only reconnect if you switch it off and on again.
Since a was not sure if the functionality came from the sattelites switching the clients around, or the clients switching AP's i had to ask :-)
thanks !
