GuyVerachtert
Sep 27, 2019Aspirant
Orbi
Hi Everyone, When using an orbi with satelites, are the satelites choosing what AP the client device should connect to, or are the client devices "roaming" thru the network ? Kind regards, ...
GuyVerachtert
thank you for your reply.
So if a device does not support roaming, the mesh network has no advantage ?
kind regards,
Guy
Sep 27, 2019Guru - Experienced User
Only for roaming. To get a device to connect to any particular wifi course, the devices wifi radio would need to be temporarily turned off then back on.
