Hula
Nov 25, 2019Follower
Orbi
Is there a way to turn off the 2.4 GHz band or be able to select a channel. Thank you,
CrimpOn
Nov 25, 2019Guru - Experienced User
Using the Orbi web interface, it is possible to:
- Reduce the transmit power of each WiFi band (2.4G and 5G separately)
- Stop broadcasting the SSID (each band separately)
- Select the channel (each band separately)
This is on the Advanced Tab->Advanced Setup->Wireless Setup
"Turn off completely". No.
One wonders what the desired result is. Is there some problem this is supposed to solve?
