DJThompson
Dec 31, 2019Aspirant
Orbi
Is the Orbi trio band compatible with a Motorola Arris Surfboard sb6141?
Dec 31, 2019Guru - Experienced User
The sb6141 is a modem only device. Orbi should work fine with it.
I've used it with an arris sb8200 without issues.
DJThompson
The reason I asked is that the arris surfboard we have is 7 years old. Not the same as the model in your response. So, does the Arris sb6141 still work with Orbi? We have issues with getting kicked off our wifi regularly. Thanks,
