leffcombs
Jan 15, 2020Follower
orbi
Im using orbi Orbi Rbr50 and is weak tv breaks up and freezes, what extender would work, can I get a extender and connenct to ethernet cable for good reception and add tvs
Jan 16, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
leffcombs wrote:Im using orbi Orbi Rbr50 and is weak tv breaks up and freezes, what extender would work, can I get a extender and connenct to ethernet cable for good reception and add tvs
