SGoettler
Mar 25, 2020Aspirant
Orbi
I purchase the Orbi system because I have an office in a different building on my property. It is about 15 feet away from the corner of the house where the satellite is located.. The signal strengt...
Mar 25, 2020Guru - Experienced User
Which Orbi model did you purchase? 20 or 50 series?
Building materials will effect wifi signal travel.
You may want to look in to buried LAN cable from the home out to the office building then place a RBS there.
SGoettler
House is 1720 sq ft. Router and Satellite are about 35' apart. There is no color on the satellite. When it powers on it is clear and then it goes off.
I assume the 20 series since it is RBR20 and RBW30, it is not the RBS.
The satellite is in the further corner of the house that is closest to my office.
Inside the house my PC always connects to the satellite which shows full signal strength. When I go into my office it drops off to 1 bar.
I updated the firmware today on the router and it shows the satellite is up to date.
Besides burying a cable what are my options? If I go back to a cable, I will go back to use the Nighthawk non-mesh. It is a better router IMHO.
- FURRYe38Mar 25, 2020Guru - Experienced User
If the Office building is on the same power circuit as the home, it maybe not be, you could try Power Line adapters. They have to be on the same power circuit to work correctly.
The RBW probably isn't strong enough to get signal thru two walls at that distance.
- SGoettlerMar 25, 2020Aspirant
The buildlings are on different power feeds.
That's not good news the RBW20 is not strong enough when someone on here recommended that for me.
I think the 50 series has more power.
You could try adding another RBS20 to feed off the RBR, the daisy chain the RBW placed in the office to feed off the RBS20.
