CMSum
May 20, 2020Follower
Orbi
I want to exten my orbi to a guest house approx 100 ft from main house that has week reception of the house orbi network. I have an Ethernet cable that runs from house to the guest house. If the orbi...
tomschmidt
May 20, 2020Virtuoso
Yes, use the wired backhaul to the satellite in your guest house. If possible, do not run the cable through a switch between the router and satellite. If you do have to use a switch, you need one that does not have green power-saving features (802.3az spec),
