stown71
Nov 12, 2020Aspirant
Orbi
I am having trouble with loosing bandwidth. My service provider is telling me the issue is from the orbi setup. He led me to look at the channel bands and said we are not using the best channel, but ...
Nov 12, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
Be sure to test speeds with a wired PC connected to the RBR for accurate speed results.
- stown71Nov 12, 2020Aspirant
how do I know what firmware is there?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? I use Utah Broadband. I called them and they determined signal to house is uninterupted.
I confirmed signal coming intot he house is as it should be, but when it comes thorughthe Orbi I loose about 50% of both upload and download.
I don't know. How do I tell?
I believe the distances are good. The two satelites are on the main floor, and the rbr is in the basement where the wires come in.
I did the diagnostics on my computer and it says I am using current channel count 3, best 2.4 = 11, best 5 is 144, but I have no idea how to change this / test this.
Any Wifi Neighbors near by? If so, how many?There are about 7 with decent signal, another 7 with almost no signal
I have no idea how to do this.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Sorry - no idea what this is either...
- FURRYe38Nov 12, 2020Guru - Experienced User
Do you have a friend, nieghbor or family member who can help you with this?
