Slothtony
Nov 21, 2020Aspirant
Orbi
I have tried everything from power cycling, to factory reseting, the router will not work no matter what I try and do, I tried to talk to netgear representatives and they give me the same thing as onl...
Nov 26, 2020Guru - Experienced User
Sounds like the RBR is bad if the top ring does not turn on and start to blink WHITE.
Try a different Power adapter, like the one from the RBS if you have one.
IF the top ring is not turning on at all and blink WHITE afterwards, then the RBR needs to be replaced.
Slothtony wrote:
I have tried everything from power cycling, to factory reseting, the router will not work no matter what I try and do, I tried to talk to netgear representatives and they give me the same thing as online does, the ring light on top of router wont light up it wont turn amber when reset button is held. I dont know what to do
