bythebay
Apr 01, 2021Aspirant
Orbi
Hello, I need some help with the resetting the admin/password for Orbi RBK50. I purchased the RBK50 from Amazon as an openbox from Amazon Warehouse 03/29/21 and received it today 04/01/2021. ...
- Apr 01, 2021Dang, didn't think it was that easy! I will do that and Thanks!
CrimpOn
Apr 01, 2021Guru - Experienced User
bythebay wrote:Hello,
The setup process was a breeze on the app until the "Login Requried" section where the username is: Admin
Since this was a previously returned item, I'm pretty sure the person that returned it had previously setup a password
and also completed the password recovery questions section and so far I haven't found any answers on how to reset this.
Just do a Factory Reset on the router and the credentials will be reset to "admin" and "password."
The WiFi will be set to what it printed on the product label.
https://www.youtube.com/watch?v=cMw4ePACgc4
Good Luck
bythebay
