bythebay
Apr 01, 2021Aspirant
Orbi
Hello, I need some help with the resetting the admin/password for Orbi RBK50. I purchased the RBK50 from Amazon as an openbox from Amazon Warehouse 03/29/21 and received it today 04/01/2021. ...
- Apr 01, 2021Dang, didn't think it was that easy! I will do that and Thanks!
alexusman
Apr 04, 2021Aspirant
I agree that Orbi system needs to support hard wired ethernet backhaul. I have had so much trouble with my satellite that I have actually just turned it off. I see posts in which Netgear employees acknowledged the need for this feature. How long should it take?
CrimpOn
Apr 04, 2021Guru - Experienced User
alexusman wrote:I agree that Orbi system needs to support hard wired ethernet backhaul. I have had so much trouble with my satellite that I have actually just turned it off. I see posts in which Netgear employees acknowledged the need for this feature. How long should it take?
This entry appears to have been added to the wrong post. The Orbi system already supports ethernet backhaul between satellites and router and also between satellites.https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
