Tony-W
Jul 31, 2021Follower
Orbi
Hi. have the Orbi systems and I just about to change internet providers. They have the the following routers: Netcomm NF18MESH D-Link Viper 2600 Which one is best for my existing system. Is there ...
Aug 01, 2021Guru - Experienced User
If you have a Orbi mesh system already, then ask the ISP for a modem/ONT option only. You don't need another wifi router in front of the Orbi router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
If you do have to get a modem/router combo, Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
We don't have any information on those items you mentioned.
