Kirlieq
Aug 27, 2019Aspirant
ORBI45 authentication problem
My kids are trying to join each other in the new Terraria update from their mobile devices and are being asked authentication questions that I assume I have to answer as the account holder (High Scho...
Aug 28, 2019Guru - Experienced User
Is it the Terraria site asking for this or the netgear gui asking these questions?
From you putting ORBI45 in the title, it makes it look like you left the ssid with the factory ssid. If you didn't setup security quesions, it'll still ask for them and you are unable to put in correct responses because they weren't setup correctly. Just trying to figure out exactly what is going on.
Are you able to log into the orbi gui? routerlogin.net? or is this where the issue lies?
Retired_Member
Aug 28, 2019
plemans wrote:Is it the Terraria site asking for this or the netgear gui asking these questions?
OP said this..."My kids are trying to join each other in the new Terraria update from their mobile devices "
- plemansAug 28, 2019Guru - Experienced User
Retired_Member Just made me wonder why the OP is posting to the netgear forums if its an issue with Terraria. If its an issue with terraria, your response is correct. with that said, I have seen orbi act a bit wonky and asking for router login info when accessing certain sites. I haven't experienced it in a while but I have experienced it.
- Retired_MemberAug 28, 2019
plemans wrote:Retired_Member Just made me wonder why the OP is posting to the netgear forums if its an issue with Terraria. If its an issue with terraria, your response is correct. with that said, I have seen orbi act a bit wonky and asking for router login info when accessing certain sites. I haven't experienced it in a while but I have experienced it.
yes...I thought the same. Although it's a valid question, if even fact it deals specifically with the Terraria site, it probably should have been posted else where. Thanks
- KirlieqAug 28, 2019Aspirant
I have figured out that what I did wrong was change Orbi settings from router to access point when I should not have (I need a seriously large Computers for Dummies book!). After I did that, I no longer had internet access (even with an ethernet cable installed from the Orbi to the computer- can't figure that out.) Long story short, I reset the Orbi to factory settings and reinstalled it, BUUUUT now I still have no wifi except to my desktop and iPhone. By all appearances, the Orbi is working (no lights on) and iPad indicates that it is connected to the Orbi, but I don't actually have a connection on my iPad. My laptop, my kids' computers and their iPad cannot connect. I'm really frustrated. Somewhere along the way, I changed the authentication questions and answers, but now, when I try to log in on orbilogin.com or orbilogin.net, I get a login window for Microsoft Edge and I have tried all of the UID/PW combinations that I can think of, but can't get logged on to make sure the router is now set to router and not still on access point. After a few attempts, I get the authentication questions that I had changed and I put in the correct answers, but it gets me no-where. So frustrated. I'm thinking I'll look into a different brand.
