Kirlieq
Aug 27, 2019Aspirant
ORBI45 authentication problem
My kids are trying to join each other in the new Terraria update from their mobile devices and are being asked authentication questions that I assume I have to answer as the account holder (High Scho...
Retired_Member
Aug 28, 2019
plemans wrote:Is it the Terraria site asking for this or the netgear gui asking these questions?
From you putting ORBI45 in the title, it makes it look like you left the ssid with the factory ssid. If you didn't setup security quesions, it'll still ask for them and you are unable to put in correct responses because they weren't setup correctly. Just trying to figure out exactly what is going on.
Are you able to log into the orbi gui? routerlogin.net? or is this where the issue lies?
OP said this..."My kids are trying to join each other in the new Terraria update from their mobile devices "
Aug 28, 2019Guru - Experienced User
Retired_Member Just made me wonder why the OP is posting to the netgear forums if its an issue with Terraria. If its an issue with terraria, your response is correct. with that said, I have seen orbi act a bit wonky and asking for router login info when accessing certain sites. I haven't experienced it in a while but I have experienced it.
- Retired_MemberAug 28, 2019
plemans wrote:Retired_Member Just made me wonder why the OP is posting to the netgear forums if its an issue with Terraria. If its an issue with terraria, your response is correct. with that said, I have seen orbi act a bit wonky and asking for router login info when accessing certain sites. I haven't experienced it in a while but I have experienced it.
yes...I thought the same. Although it's a valid question, if even fact it deals specifically with the Terraria site, it probably should have been posted else where. Thanks
